Sno Cat
Anyone out there got helpful hits to change oil & filter? Will a Rec Lift work well on this chasis or are there better alternatives? This newbie to this chasis will appreciate ideas.
Thanks.
Thanks.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I'm sure one of those lifts would work. I myself simply placed my floorjack behind the access panel and jacked mine up.
sinjin
I have a rec-lift in the garage shop and it works great. Beware that yamaha uses gorillas to tighten the filter on when it comes from the factory. First change can be a pain in A** to get the filter off.
impalapower
sinjin said:yamaha uses gorillas to tighten the filter on when it comes from the factory.
Using those handy Channelocks is the ticket.
