Apex/Attak Mods??
DJrides
Lebanon, CT
With the new motor and FI, I wonder how easy its going to mod this configuration. Unless Yami releases the ignition and fuel maps, and allows reprogramming, engine mods to these sleds may be a little difficult (like the AC FI's). Some of the AC FI mods used a somewhat klugey fuel pressure regulator to change the FI rail fuel pressure.
There are now systems for the AC EFI that allows you to "plug & play" and adjust all settings but allow the ECU to act as normal as well. I'm pretty sure you will see systems very similar to the Boondocker box for the other EFI systems.
Well if they do release the ignition and fuel maps it will be easy to do. I found out you can do it right on your display module on the sled.
