Apex cooling system waterpump flow rate
bigdog_mike
Fraser, MI
Anyone know what the flow rate is on the Apex cooling system water pump? H.ave my Apex motor mounted in a SXS with dual radiators and 24' of 1" hose plus the second radiator is about a 12" above the motor. Need to know whether I should add a second electric water pump to this cooling system to accommodate the increased volume of cooling hose and added radiator will put on the Apex motor water pump...
I would call and talk with Jim @ OSP as they have quite a bit on knowledge on what you are doing.
