Apex Disassembly
YammiMoose
In a place where it SNOWS every day
I spent some time taking apart my GT to get to know it better. I found the boot for the EFI not seated properly along with loose bolts holding the headlight on. I spent way too much time trying to get the clamps tight. I used a 5mm Allen key. It didn't have what I can only describe as a ball or rounded tip on the end to get it to seat properly in the bolt. I also found I couldn't find one long enough to make an easy job of it. Does anyone know how long were the ones used in the guide by Srxspec.
-5mm "T" handled Allen Wrench
Thanks!
AIRWOLF said:
I just ordered a set of metric T handle allen wrenches 10" long
I'll have to see where i ordered them from
The set I ended up buying had long ones until it got down to 6mm than after that they were all short ones.....
I saw two other sets over the weekend that were the same way.
Thanks....
I bought the ones below off ebay was around $25 with shipping. not sure of exact lenth but they work fine. the 5mm is just long enough, i think it is about 150mm(6").
