blue er
there's so many things that can be, but the basics would be checking the clutches for correct operation, verify the idl rpm specs are at 1500 when warmed up, but my personal guess is that you have a bad plug even if there new, try a set see what happens.
also is the check engine light on?
Nytroman
- Dec 12, 2007
- Prince Albert, Sask
- 2008 FX Nytro
I checked the clutches a little and they seem to be fine, but I haven't got in to deep yet. Idle is at 1500 bang on and there is no check engine light or error codes coming up. I think that we will put a new set of plugs in next but won't have time till next weeknd to try that.
