Mercer5
- May 31, 2007
- Wales WI
- 2014 Viper, 2001 SRX, 1990 Sno Scoot, Kitty Cat
I see these was a thread a while back on some of you who used these. Just wondering how they have been. I am on my second set of y-pipes. I am pondering either new OEM version or the stainless ones offered aftemarket, although arent the new OEM version now stainless to? My gaskets weathered the strom but the y pipes broke at flanges.
Any help? Going on loing trip in 10 days so time is of the essences !!!
thanks
Jim
thanks
Jim
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
You didn't post a link to them, or any info as to who makes them?
Mercer5
- May 31, 2007
- Wales WI
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
You can also get them from Hi-Perforamance Engeeering they work great they also come with gaskets too.
bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
I put them on at the beginning of the season and the exhaust started leaking again after 500 miles. I am going to tear the sled down this weekend and will post back with what I find.
Mercer5
- May 31, 2007
- Wales WI
Pleeeeeeeease post back, I just ordered so I wont install quite yet, need to rivet y pipe holder back anyways since button head bolts were stuck.
dmaxx
- Apr 5, 2006
- sw Michigan
- 2015 Viper RTX, 2012 Apex XTX, 2010 Vector LTX, 2000 AC Z-370..fast
- White Pigeon, MI
I replied to previous post in regard to these. I installed them on my Attak last year in between rides. Did not have to pull pipes or weld, easy install. So far, so good. I have about 800-1000 miles on them with no problems. Good fix especially in season with a time factor between weekend riding. If it had been at the end of the season, probably would have installed new pipes.
bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
I will certainly post what I find... it won't be until Sunday though.
I did try to install the kit without pulling the y-pipes out as dmaxx suggested, but cutting the old flanges off was a total b**ch using a cutoff wheel on an air angle die grinder because the titanium is such a hard metal. I ended up getting frustrated and pulled them out and cut them off on a chop saw. I did have to heat the new flanges up with a torch to expand them enough to slip over the pipes.
Overall I was impressed with the quality of the kit and I am really hoping that the leak is due to something stupid like a loose doughnut clamp!
dmaxx
- Apr 5, 2006
- sw Michigan
- White Pigeon, MI
I was able to cut the old flange off, took a little doing but done. Then I sanded/filed the old pipe and slipped the new flange over. They are very tight. Had to tap them on. Make sure everything is even so it lines up to the flex pipe, I used orange permatex also to help seal them. Overall, I was impresses and it did save a lot of time by the time ordered them form ebay and installed, I was riding the following weekend. If I had found pipes and ordered them, I doubt I would have had them by the weekend let alone had them installed. That was a big factor for me, did not miss a ride.
Mercer5
- May 31, 2007
- Wales WI
So if I decide to replace the y pipes, are the new OEM versions stainless? I know the originals were titanium.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
yes the new oem are all stainless now.
Mercer5
- May 31, 2007
- Wales WI
Finished install last night with these flanges, it's a pretty nice tight fit, I don't see any reason why they would not be the answer versus buying new y pipes. It was easier second time around to drill out the rivets holder the hanger bracket, the rivets were loose anyways.
I did used some Permatex muffler when I slid flanges over y pipes, I also put pipes in freezer for hour prior.
We'll see how they work, doing a 2 night trip to Ashland WI next weekend
Stay tuned
Jim
Stay tuned
Jim
Perhaps it is time to begin production on these?... built em back in 2005 along with a header. Obviously they were designed to eliminate the donut... though I did build copper donuts for a brief period back in 09 or 10... these could be a better solution. As one can see, these have been well tested.
