nospeedlimit
- Sep 7, 2007
Anybody having problems with the brake on the apex's-- i have to squeeze my brake almost 3/4 of the way to the bar to get marginal braking-- how do you adjust?
vmaxx05stud
reading my owners manual it sayss if the parking brake wears then it effects the brake performance. it says to adjust the cable w/ the lock nut to gain it back as long as its not worn out.
rightarm
nospeedlimit said:Anybody having problems with the brake on the apex's-- i have to squeeze my brake almost 3/4 of the way to the bar to get marginal braking-- how do you adjust?
Sounds like you need to bleed your brakes.Reason being Old brake fluid or air in the lines could even be your brake pads need to be changed.Start there check thickness of brake pad if worn re-place if not bleed brakes.
T-Bone
Time for new brake pads.
