Jeckylll
I am looking buy a 2006 APEX Gt and was wondering what parts i would need to convert it to a Attack GT.
I know i need a 136" track and a Tunnel extension that is givien. I am not a big fan of rail extensions. I would like to keep the GT adjustable rear suspension.
Can i convert my APEX Gt skid to an ATTACk GT or should i buy a new to me Attack GT Skid.
Do i need to do any tunnel modifications or heat exchanger modifications.
I see people changing the skid from ATTack to Ski-Doo or ARtic Cat. Is there someting wrong with the Attack Skid? Is it a change for change sake?
I am a 300lb rider who like to ride off of the grommed trail when ever i can. IF anyone has any recomendations.....
Probalby the right answer is to buy an attack GT instead of converting but i really like the black apex gt sled.
DANATTAK
if you have the means i would just buy a black attak gt o7 or the 08 are all called apexes just the longer one is a ltx i think.
Jeckylll
taxes in for a 07-08 Attack in Saskatoon is 15g..... i can buy a 2006 apex gt with 800 miles for 9900 taxes in. That gives me 5g to longtrack. I could supercharge and longtrack for a little over 15.
Stupid taxes 11% in Saskatchewan.
Unless i can find a Attack in montana.
Apex18
Just make sure when you extend it to a 136 inch track you know what it's called...Attak not Attack!!
schmeg
Using track extensions on the Apex is no big deal and works great. Just understand you will need a shock revalve and stiffer spring to compensate for the increase in leverage. I went to 136 this year and did the full monte with the 1.5 inch Intense. I even installed 6 extra wheels and went to extros with a fully clipped track. I went with the 6.1kg spring which may be a little too stiff for my 160lbs. I spent 1500 or so for all the parts, but it can be done a lot cheaper. PM me if you need more info. Jay
Jesus, I thought we grabbed our ankles as far as taxes go....
Honk
I long tracked my RX a couple years ago and really liked it. The rail extens are fine. no trouble at all. I used tracks usa. hyfax the whole rail length. Tunnel extension was also easy! Made the sled look much better and rode great too! They had a kit that was like 6 hundred and fifty bucks total. Track, and both extens. I ran the track to tight and wore the hyfax down to fast. Just do it!
Miskow
- Jan 29, 2023
- Minnesota
- 2018 sidewinder, 2023 sx Venom, 2006 Apex
Does the gearing need to change when doing an extension?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
This post is 15 years old. You might want to start a new thread
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
The 136” tracked sleds were always geared one tooth lower than the short track versions and usually had slight clutching changes as well.
136 sleds have a 23 top gear vs the 24 top gear of a 121 sled and the 136 also uses the white spring in the secondary vs the pink.
