BlkNytro
Well atleast I think it is. My dad was on a lake and he was doing about 90 at WOT and then he heard a few noises and the sled died out on him. When he tried to start it up the revs would pulse from about 2k to 3.5k. The engine light was on and flashing. Thanks for any help.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
try to see what code comes up on gauge...go from there.
Dan
Dan
BlkNytro
How do I find it on the gauge cause I looked.ROCKERDAN said:try to see what code comes up on gauge...go from there.
Dan
yamahahaapex
usually a flashing number by the yellow light.
apex4
Hi, just download service manual it will tell how and have the code # referance to what is wrong. it can be downloaded in the "frequently asked questions" above your post.
BlkNytro
I looked again and there was no numbers flashing...
sledneck22
If the engine light is flashing there will be an error code that will flash where the speed is normally displayed. Just turn the key to the run position and see what happens. If you get nothing then try to start it and see if there is a code that pops up. What kind of noise did it make? Check the tightness of the chain in the chain case and see if something in there didn't come apart. Have you checked to see if you have enough oil in it also?
BlkNytro
Found out what the problem was. Apparently when the shop did the oil change for us they didn't properly put it back, it just didn't fail till after 600 miles.
bankershrs
- Sep 19, 2008
- Roscoe, IL
- 2017 Yamaha Sidewinder RTX LE
Didn't put what back properly?
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
BlkNytro said:Found out what the problem was. Apparently when the shop did the oil change for us they didn't properly put it back, it just didn't fail till after 600 miles.
What did they forget?
BlkNytro
I believe it had something to do with the intake tubing or something.I remember read about it on here that it can cause a problem. It's my dads sled this is what he told me.
