TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Hey just wondering if any one has any suggestions why my apex mcx mtn seems to load up and die out when cold, after it warms up it runs fine. I thought maybe a vacuum leak, but my digital boost guage/controller is showing negative at idle.......exhaust leak maybe?????
ken_climb
Maybe try adjust your stock co settings up or down.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
I had the co at -20 with the old mapping got the new mapping(310) this year figured it was a little lean so adjusted it to -5......didn't really seem to make a differenceken_climb said:Maybe try adjust your stock co settings up or down.
Veedy
- Mar 20, 2005
- Revelstoke, BC
- www.farwestfilms.com
You figured it was lean ? no AFR guage ? try +20, can't hurt.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
sorry I wasn't clear....it was doing it at -20 also....the reason I figured it was maybe lean it seemed to hesitate on the bottom to middish throttle
