Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Having done all my own maintenance on my 04 Warrior through the years, I'm looking at this new Apex and wondering what is the best way to get at the Oil Filter on this beast? The Warrior is a REAL pain to get at! Remove Air Box, Battery and bracket and then you have access to the Oil Filter! Now before I start digging into this new Apex who has done it? THANKS
cmharcou
I've done it lets see...OVer a dozen times. Its never fun and there is no easy way. I think ulmer racing makes a kit that moves it to the front. Thats the way they should of made them from the factory. It usually takes me about 3 hours from start to finish making sure I don't drop any bolts or allen wrenchs down the sled. I take my time. I gotta remove the skid plate as well.
vx700xtc
After you get the headlight pod off it is exactly like the Warrior.
Bob Miller
- Apr 19, 2003
- New Milford CT
vx700xtc said:After you get the headlight pod off it is exactly like the Warrior.
So windshield first than Headlight pod? Any instructions?
sxray
- Mar 2, 2006
- grand blanc, mi
- apex
No need to remove windshield, it comes off with the headlight pod. Only two bolts hold pod on, one on each side.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
no two hex heds one each side side then slide foreward and up. after you remove the top dash piece it is held in with 1/4 turn allen heads and thats after you take off the chrome ring two phillips head screws.
apex55
Panels off
Light pod off
airbox off
battery out
battery bracket out
Oh there it finally is.
Only thing with the ulmer kit is you loose storage space in front. I use a nose bag and it won't fit with this kit. It is a great design though.
Light pod off
airbox off
battery out
battery bracket out
Bob Miller
- Apr 19, 2003
- New Milford CT
Great help!
Its not that its hard to do,just a lot of steps to get at it and replace everything you just removed !
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Kind of a pain but... it gives you the opportunity to look the sled over for issues (before they become a problem) from the inside out every year.
ersky
- Feb 6, 2009
- ont canada
- 06 apex gt s/c (sold) 04 rx warrior apex converted 2 stage bender turbo. 12 venture gt (getting old)converted to 11 apex
building a custom apex
i took the battery box off the bracket put proper lugs in the tube so u only have to remove it not the whole thing every time i think it makes it a little easier
