Mad Russian
Just wondering if anyone had there power steering unit fail yet ? Mine did and im trying to figure out what went wrong ... I was thinking maybe a fuse but i have no clue where this fuse is located... Any feed back will be greatly apreciated... Thanks
Malibu
just after i bought mine it stopped working and the light came on.sat here in heat oveer night and than it was fixed.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
Were you doing alot of tight/twisty trails at slow speeds? The power steering motor will shut down if it over heats. (not 100% on this but the Grizzly's have this feature)
Mad Russian
Yea there was a lot of turns but now its in my heated garage and sill dont work...
larsd
- Nov 7, 2011
The EPS shut down after the sled had been standing still on the mountain in -26 celcius for a while, but shortly recovered when the engine warmed up again.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
im guessing its a frozen/bad relay....check the back of your owners manual and the wiring schematic
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Apparently, there is a diagnostic mode where it will throw a code should the EPS light comes on...possibly low battery voltage, etc.
There is a fuse for the EPS under the airbox near the main fuse.
larsd
- Nov 7, 2011
It happens to me when it is really cold, but as soon as the engine heats up the problem is gone. Really weird feeling driving without eps.
