redrx1rkt
- Apr 20, 2005
- South Shore of Lake Ontario
- www.snowdevils.net
As for shock re-valving...I have found that by having all stock adjustments set as stiff as possible (preload, etc), you get more flexibility from the MonoShock remote adjustment knob. MAX HARD will practically NEVER bottom out. MAX SOFT still very soft (but this also affects "sit in" and makes you sit lower) and bottoms easily. I set my dial three settings back from MAX HARD and I get a smooth ride over small stutters, yet a firm but absorbent ride (without bottoming) over larger 1' + bumps.
The bottom line is that I have found shock revalving unnecessary with the proper setup.
SRXSex
If not studded remove protectors to cure snow build up.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Bigest pro of all we have totallyamaha to help us with any con that may come up keep up the good work guys
