Apex RTX A-Arms
kotapug
Southern Minnesota
I set my suspension on my sled to the great suggestions that I received from you guys and has helped out alot. The ? I have is the A-Arms are now straight across and sometimes angled down. Is this the way yours are sitting ? To me it doesn't look right. More pressure in the floats they are at 35psi or do I need more pressure on the front spring. I'm also geting enough front end lift to where when I accelarate my lights are way off but are good under moderate accelaration. Transfer rods or combanation of everything ? :o|
My set-up is 55 psi in the float with 13 mm sway bar and limiter strap shorten 1 hole.weight transfer set up between half way and min.I never adjust my weight transfer past half way,not enough ski pressure for good cornering.
How many lines on the weight tras. ? Does the 13 mm help out alot ? I have been wating for mine this will be going on week 3.
Ported Hornet said:
RockRTX is a 06 with a mono, will be a totally different setup.
oop's! I did not read close enough,mine is a mono,different set-up that 07 rtx.
And yes the 13mm bar help a lot for ski lift.
make the A arms level with ground....on my 06 RTX i achieve this with my setup by having 40-45lbs air pressure in the fox floats WITH NO WEIGHT on front end.
Dan
