kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
I have searched far and wide for this answer to life, but i cannot seem to find it.
What is the max height you can go on an apex with and without the tunnel/heat exchange protectors. Also max height with 9T and 8T drivers. Right now I have 9T drivers.
What is the max height you can go on an apex with and without the tunnel/heat exchange protectors. Also max height with 9T and 8T drivers. Right now I have 9T drivers.kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
Really need to know this so I know if I have to trim down my 2" paddle track down.
Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
track
I installed a 1.75 on a 40th apex...I had to remove the tunnel protectors and the protectors on the front coolers...If you go with a 1.5 you can leave all protectors in place. It is close but doesn't interfere ..I have a 1.5 on my apex Stock drivers
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Re: track
X2 with a 8T you can get a 2" in
Newfie Apex said:I installed a 1.75 on a 40th apex...I had to remove the tunnel protectors and the protectors on the front coolers...If you go with a 1.5 you can leave all protectors in place. It is close but doesn't interfere ..I have a 1.5 on my apex Stock drivers
FLYBYU
Re: track
X2 with 8T. I run 9T with 1.5" no studs and all protectors.
APEX 06 said:Newfie Apex said:I installed a 1.75 on a 40th apex...I had to remove the tunnel protectors and the protectors on the front coolers...If you go with a 1.5 you can leave all protectors in place. It is close but doesn't interfere ..I have a 1.5 on my apex Stock drivers
kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
How about 9T drivers and no tunnel protectors? Hoping it will warm up so I don't freeze out in the garage while removing the protectors. If I have to drop down to 8T i'll be getting extroverts and clipping the other 2/3rd of the track.
