Bigfish
- Sep 7, 2009
- 15 RS Venture TF
04 RX-1 ER
Finally got around to changing the seat over to an Apex one, very easy! I used a Dremel cut-off to trim the tank cover, I marked the tank cover 3.5" in the middle and used the front edge of the Apex seat to mark the right curve to the points, worked extremely well.
My question, as I have raised the seat I now need to raise the bars as well. I am trying to decide how much to raise them, I am currently thinking about the Rox adjustable riser, but not sure. Any suggestions from those who have done it would be appreciated. Please advise what pivot and riser you used, I am 6' 4" and predominitely a long distance groomed trail rtider.
Thanks for any responses.
GUKROKIT
I did the apex seat and rox adjustable height riser(6-8.25").I have the riser all the way up and it allows me to stand straight up,but I'm 6ft tall.You may want more if you are 6'4"tall,depends on the rise in the handlebar.I used yz 125 handlebars which had way less rise than the stockers.I figured mine by standing up on the machine then hold hands where you want them,have a friend measure from your hand to the current handlebar.I bought 05 rx1mountain throttle,brake, choke,and parking brake cables.Also had to extend all the wires going up to the bars.You may be able to cheat and reroute some of them to get the extra length.I was trying to bury all the plugs into my crossbar pad.You may have more flexibility using the big stock pad and handlebars.Definately worth the trouble.I stand at least half the time now and ride groomed trails that get beat up quick on the weekends.
Bigfish
- Sep 7, 2009
- 15 RS Venture TF
04 RX-1 ER
GUKROKIT said:I did the apex seat and rox adjustable height riser(6-8.25").I have the riser all the way up and it allows me to stand straight up,but I'm 6ft tall.You may want more if you are 6'4"tall,depends on the rise in the handlebar.I used yz 125 handlebars which had way less rise than the stockers.I figured mine by standing up on the machine then hold hands where you want them,have a friend measure from your hand to the current handlebar.I bought 05 rx1mountain throttle,brake, choke,and parking brake cables.Also had to extend all the wires going up to the bars.You may be able to cheat and reroute some of them to get the extra length.I was trying to bury all the plugs into my crossbar pad.You may have more flexibility using the big stock pad and handlebars.Definately worth the trouble.I stand at least half the time now and ride groomed trails that get beat up quick on the weekends.
Thanks, that's the type of info I was looking for!
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Bigfish said:GUKROKIT said:I did the apex seat and rox adjustable height riser(6-8.25").I have the riser all the way up and it allows me to stand straight up,but I'm 6ft tall.You may want more if you are 6'4"tall,depends on the rise in the handlebar.I used yz 125 handlebars which had way less rise than the stockers.I figured mine by standing up on the machine then hold hands where you want them,have a friend measure from your hand to the current handlebar.I bought 05 rx1mountain throttle,brake, choke,and parking brake cables.Also had to extend all the wires going up to the bars.You may be able to cheat and reroute some of them to get the extra length.I was trying to bury all the plugs into my crossbar pad.You may have more flexibility using the big stock pad and handlebars.Definately worth the trouble.I stand at least half the time now and ride groomed trails that get beat up quick on the weekends.
I added an Apex Mountain seat and Apex bars to my RS. I am 5' 9"/10" and wanted to stand occasionally so I extended all of my cables with Vector Mountain cables and used a 5" Rox pivot risor and a 1" Powermadd riser block I had lying around. If you go with Apex bars you might want more riser than I went with. Here is some info on my mod. G.B.
http://www.ty4stroke.com/viewtopic.php? ... c&start=15
glas0233
- Sep 30, 2014
- Minnesota
- 2003 yamaha rx1, Past sleds: 1990 Arctic Cat Prowler, 1996 Arctic cat 440z, 2004 Ski Doo Renegade 800, 2005 Arctic Cat M7
I am going to do this mod as well and had a question, for the back plastic piece that you remove to get the seat off, does that still fit with the apex seat or do you have to buy a different piece? Thanks
GUKROKIT
Still works
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Sorry to bring back a old post here lads but I just bought a apex seat for the RX1. I will be doing thing mod when it arrives. I just want to clear up some things before I go ahead with this. What did you use to cut the gas tank cover with, just a dremel or something? What were the measurments and how do you draw the line out. Just measure 3 1/2" and taper down to the edge. Simple as that or what? Just looking for a few more details thats all. Thanks.
I used aviation snips also- lay masking tape on 3.5" in centre and fade out to nothing at edge. Here are some other tips:
http://www.ty4stroke.com/threads/apex-seat-and-rear-light-conversion-a-few-tips.113807/
Jim04RX1
- Nov 23, 2014
- Hastings, MI
- 2004 Yamaha RX1ER
Does this mod sit you up higher? If so that would be great on my knee's!
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Yes, about 3".Does this mod sit you up higher? If so that would be great on my knee's!
Jim04RX1
- Nov 23, 2014
- Hastings, MI
- 2004 Yamaha RX1ER
I will definitely do this mod then thanx's YammyRX1 My knee's will thank you too!
Jim04RX1
- Nov 23, 2014
- Hastings, MI
- 2004 Yamaha RX1ER
Do you know if a NytroMTX (08) would fit the RX1?
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Look at the difference between middle and last picture (seat and bars)
derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
Having trouble finding a apex seat that is all black or black with blue, have found a 2012 vector seat and an attack seat unsure of attacks year, but would either of them two work for the apex seat mod? Sorry just got this sled been reading on this site every night trying to get familiar! Thanks for any help, forgot to mention it will be going on a 04 RX1
jong22250
- Apr 6, 2014
- syracuse, ny
- 03 yamaha rx1
Check with hibshman25 he has tons of seats I got mine from him great to deal with
