Moontree
- Dec 4, 2014
- 2003 Yamaha RX-1
Question being can I reuse my same bottom board? Thus avoiding the light plug issue ( yes its minor, but I'm thrifty)
jong22250
- Apr 6, 2014
- syracuse, ny
- 03 yamaha rx1
Apex seat as the trunk in it u could try it bottom are slightly different though its just some staples and glue if it dont work
jong22250
- Apr 6, 2014
- syracuse, ny
- 03 yamaha rx1
Plus the plug isn't a issue just cut the end off your rx seat and buy butt coneccters with heat shrink tubing on them its 5 min to wire the new plug on just leave about 3 inchs of wire on ur rx plug
Spikester26
- Nov 6, 2013
- Sanford, Michigan
- 2005 Yamaha RX Warrior
2003 Yamaha RX 1
1992 Yamaha Phazer
1988 Yamaha Exciter
I just taped mine off as you see above and cut it with my Dremel. It was like cutting through butter. Very easy.
Jim04RX1
- Nov 23, 2014
- Hastings, MI
- 2004 Yamaha RX1ER
Thanks to hibshman25 I got lucky and he hooked me up with same color seat. Now other than the wiring am I safe to say original exhaust covers and light will fit the seat?
If it will fit underneath I plan on converting plugs to weatherPack connector and terminals.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
If memory serves you might have a slightly bigger gap between seat and plastic exhaust covers but paint the tunnel flat black in this area and it isn't noticeable.
