Apex Skid Rebuild
rkkoeb
Green Bay
None right now
So I decided to pull the rear skid out of my 09 Apex and completely rebuild it for next winter. Had the shock rebuilt, put new slides on and had the parts powder coated. Just some pics of the work that was done.
Tear down of skid getting ready to send parts to sand blaster
Parts back from sand blaster ready to have powder coated
Parts back from powder coating
skid back together and ready to go into sled this weekend. All new bearings installed. Big thanks to my buddies that help weld up a part and doing the powder coating
The PC color looks nice. Should match the sled well.
Great job looks good
Need to put a 4th wheel on the rear axle.
Looks good! Is there any a guy should know or do while rebuilding the skid? Like welding gussets? For strength.. etc? I know on my rx1 I had that problem, is it the same on an 06 apex?
Great job!
The 2010's had the better idler wheel blocks with two bolts to prevent rail tab bending and preventing them from sliding up the rail slightly.
What would be the reason of putting the 4th wheel on the rear axle? I do have a spare wheel and bearing that I can use.
back in
Support's the studs and overall makes the sled roll better.
Sounds good, like I said I have a spare wheel and new bearing for it. Can anyone tell me what the length of the center spacers on the shaft will need to be cut down to?
