polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
I did a search and didn't find anything but I am sure that someone has done this. It looks like the 2007 Apex snow flap is different than the 06. I am tired of having a reverse that I can't use. My flap gets stuck backing my sled off of my trailer. Do I need anything else other than the flap, do I need a mount?
abj87
polarisconvert said:I did a search and didn't find anything but I am sure that someone has done this. It looks like the 2007 Apex snow flap is different than the 06. I am tired of having a reverse that I can't use. My flap gets stuck backing my sled off of my trailer. Do I need anything else other than the flap, do I need a mount?
The new flap bolts right up to the old bracket. I used bolts rather than rivits.
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
What year flap is that? Does it work better than the stock flap. Looks nice.
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Not a good pic.of it.
blkhwkbob
Be prepared for your back to be covered with snow while you ride. I'm not sure why exactly, but it happens to both RX-1's we have with the new flap. If your coat isn't waterproof, you will get soaked as it melts off.
jsjk-4-stroke
same here i get all wet , went back to 05 flap dry now
SHAMARKEN
- Aug 21, 2003
- Johnstown,Ont
- Z1Turbo
same issue with mine will be going back to old style...
abj87
Since I took that picture it got caught in the studs on the track, so I cut off the bottom 2-3 inches (I cut along the molded line). It does does leave a big cloud of snow dust behind me but I never had an issue with getting wet. I do have a good jacket though.
Can't compare it to the old style flap, it was shredded when I got the sled.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Indy
if you want to stop the flap from catching, add a strip of 1"x 3/16" aluminum under the flap mount (inside tunnel). this will add strength and will not allow your tunnel end to bend and cos the flap to wrap up on track.
