Apex2007se
- Feb 3, 2020
- Hamiota
- Apex
Looking for feedback from those who are using barn of parts/schmit brothers soft engagement spring. What rpm are u engaging at? What rpm is your final shift at 10700? Have tried finding info but always comes up for either viper or nytro.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Guys I ride with just bought 2 2011 apexs, and a 2010 LTX GT. The 2010 had the soft spring. It engages smooth at 2500 rpm, and the one time I rode it the other night, seemed to top at 10,000. One of the 2011s with exup ran about 10,200 with the stock spring, and my ole trusty 06 rtx runs 10,600, and then a little more on a long pull. We put the triple green spring instead of the soft spring, so engagement is 4000 and really rips now. That's all I know!
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
I am using the low engagement spring I believe from Dalton, its orange, installed at the dealer, I'm thinking around 2700 engagement, not sure what the rpm tops out at, but it shines in slow tight twisty trails and when reversing, engages smoothly with lots of power throughout the shift.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
I have Schmidt's Bros spring in all 3 of our Apex's (2) 128's and a 144 All engage at 2800 rpm and run 10600 on top. I couldn't get bop to do these numbers.
Apex2007se
- Feb 3, 2020
- Hamiota
- Apex
So u are saying not same spring? Do u run stock weights stock helix? Does it still give good throttle response when cruising?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
They are not the same spring. stock weights and helix with Thunder Products secondary spring.So u are saying not same spring? Do u run stock weights stock helix? Does it still give good throttle response when cruising?
Apex2007se
- Feb 3, 2020
- Hamiota
- Apex
Anyone know angle of helix for apex I have an assortment and don’t want to buy more if I have one that is close
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Apex stock is 51/43Anyone know angle of helix for apex I have an assortment and don’t want to buy more if I have one that is close
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
True, but they are very conservative.......it compares very closely to a 48-42 Dalton shift wise.Apex stock is 51/43
Apex2007se
- Feb 3, 2020
- Hamiota
- Apex
So what helix comes with sbm stage 2
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Call them and ask.So what helix comes with sbm stage 2
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
......and let me know what they tell you.So what helix comes with sbm stage 2
Apex2007se
- Feb 3, 2020
- Hamiota
- Apex
Never thought of calling them. I’ll ask them what the spring specs are for the primary at the same time.
BryKlu
- Nov 1, 2017
- Presque Isle, Wisconsin
- 2010 Vector LTX GT
2012 XTX w/bop spring. Engages at ~2800 and pulls 10700 on top then slowly out to 11ish. Saw 109 on the speedo last weekend and it was still climbing but I made it to the bar
