Schmitty289
- Feb 6, 2023
- North dakota
- Yamaha apex mountain 2008
Nothing I do is going to clear the codes off of them if a perfectly good snowmobile won’t delete them off
Schmitty289
- Feb 6, 2023
- North dakota
Yep
Schmitty289
- Feb 6, 2023
- North dakota
These ecu s were used in 06-10 apex mtx
So the codes aren't displayed during normal operation?
What procedure are you using to try to clear codes?
Schmitty289
- Feb 6, 2023
- North dakota
No they are on the dash at all times even on good running sled
Schmitty289
- Feb 6, 2023
- North dakota
di 61 views 00
Di 62 shows 2 code on one ecu
And 1 on the other sled starts and runs like garbage on the one ecu with one code and does not run at all with the one with two code and like I said before the sled has no issue it’s a perfectly good sled I was just trying to get the codes to clear off of the ecus with the sled the other sled is the fd up one
They shouldn't be on there if it's running right, not sure whats going on there.No they are on the dash at all times even on good running sled
To clear stored codes put on 62 and toggle the grip warmer down.
As I said before replace that sub harness, I've ran into this problem before. Get a new one, or a good used one. Slide male pins into all the females and they should grip firmly.
Schmitty289
- Feb 6, 2023
- North dakota
I’ll definitely get one for my bad sled and give it a shot once I can figure out how to get and ecu flashed/ cleared
Schmitty289
- Feb 6, 2023
- North dakota
Anyone know a good parts website
If a new one isn't available anymore, there's some used ones on ebay.Anyone know a good parts website
Schmitty289
- Feb 6, 2023
- North dakota
Yeah man they are the same evidently Yamaha has discontinued making of that part to anyone know of any wreckage yards selling parts
Schmitty289
- Feb 6, 2023
- North dakota
Anyone know if an attack ecu will work on a mountain
Travis at Barn of Parts is the guy to talk to about getting parts for your sled.'
I am sure that the ECU will work
