Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
13mm swaybar will keep the skis on the ground in the corners much better than the stock 11mm swaybar. It will not eliminate the skis coming up, but it will significantly reduce it. The 13mm swaybar will ride more harsh than the stock 11mm swaybar. You will particularly notice it in uneven bumps when only one ski hits a bump. Some people found the 13mm swaybar to be too much and went with a 12mm swaybar.
The aftermarket bars are available from Pioneer Performance. Click here for link to their web site
vmaxx05stud
thanks for clearing that up swiss.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
13mm is good , if you like the sporty ride ,
12mm if you like the plush ride !
SledFreak
- Feb 7, 2005
- Ontario. Canada
Both are an improvement over stock.
