coolio
- Feb 23, 2007
Has anyone had trouble with water getting on their clutches bringing you to a complete stop? I have a 14 xtx and I can't go through water that's on top of the ice on lakes. I've never had this problem and I've owned many different yammies including 2 warriors and they went through water fine. If you hit open water with an Apex xtx you are going down! It won't skip and that scares me as we do a lot of lake riding. Yes I tried silicone in various places and duct tape but no improvement.
coolio
- Feb 23, 2007
By the way, I run C&A pro skis. However it seems that the water comes in through the tunnel not from the sides.
UP Michigan rider
- Feb 9, 2013
- Central U.P.
- 2012 Apex XTX
I don't have an answer but there are lots of videos of Apex crossing water.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Running a long track machine on water with a high lug track will not work very well. Too much track shoveling water into the tunnel. My turbo 136 will pull it through but if your not carefull it will pull the sled sideways in the water. Short tracks small lug work best on water.
34pontiac
- Nov 16, 2014
- WI
- Sidewinder
Apex
My 15' XTX
There's a post on here somewhere showing all the places to seal it and sealing behind the clutches from the motor
Ahh just found the post. I made one out of plexi glass and it worked.
http://ty4stroke.com/threads/water.80885/
coolio
- Feb 23, 2007
Thanks. Food for thought I guess. It seems odd that the track will fill the engine compartment with water. It must go in around the exhaust I guess. I literally come to a complete stop in water with total belt slippage, then I have to wait for the water to drain out and I can go again for a short ways. This is in several inches of water and it's done it since new.
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
