You guys are amazing in how you troubleshoot peoples sleds without ever getting a chance to touch them, Awesom. maybe you can help me also. 2006 Apex gt EFI.
I'm getting a code 14 before I even crank it, near as I can tell from the manual this is the sensor measuring intake vac pressure. manuel says clogged tube, tube fell off, etc. Not the case. What I don't get is how it can give that code before it even cranks unless it isn't seeing any return signal? I've read a hundred posts and repairs by you guys. I'm guilty of starting this sled 3 times a day for anyone that will listen, not letting it warm up. I didn't just didn't know!!! I assumed fuel inj. would handle it. Is it possible I'm chasing a ghost and just need plugs? I'm heading to ring out the P/W Pink and white signal wire, intake sensor to ECU. Any thoughts would be great for newbie 4 stroker. Thanks, Kevin
