Dominic lachance
- Jan 22, 2019
- Beausejour manitoba
- 2006 RS vector Gt
I’m in the process of putting a 2016 153 arctic cat m8000 skid in my 2003 Yamaha rx1 mountain has anyone done this before if there are any tips out there or anything at all can you contact me please
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I have an Arctic Cat M8 skid with custom aluminum drop brackets installed in my 2004 RX1 mountain. It's been so long I barely remember doing it lol!
From what I remember, I used the stock front holes, had spacers manufactured for the inside of the tunnel because the tunnel at the front is wider than the front A-arms. Two spacers to close the gap as worked all this time with no issues.
I had drop brackets made out of aluminum. I measured the distance from the front A-arm bolt hole to the real bold hole center to centre. I used a wooden metre stick and drilled a hole at the one end and a hole at the other end at the measured distance. I put the bolt through the tunnel and through the one hole of the stick. Then I marked the drop bracket with the other hole in the stick to get the exact hole location. I drilled 3 holes in my drop bracket and using the stick it automatically "arcs" to keep the bolt holes precise.
I had to bend my aluminum drop brackets in a hydraulic press to spread them out to allow the rear arm to fit.
There should be lots of threads on this topic from years ago on this specific forum.
If I remember correctly, I think my M8 skid is a 141 which fits the 151 Yamaha mountain track. Not sure what track would fit the 153 skid. The 141 is set back quite a bit compared to the stock RX1 Mountain skid. I installed anti-stab wheels as a precaution and after thousands of kms of flat landing, I have had zero issues.
