Arms
Hibbing,MN
Are the a arms from 08-09 different notice the only difference in part numbers is the beginning 08 is gl and 09 is hk? Some know?
Somebody posted these part numbers as different in an old post:
here are your front end part numbers
ya8hk-23540-00-PO front upper arm comp (1)
ya8hk-23550-00-PO front upper arm comp (1)
ya8hk-23373-00-00 collar 1 (2)
ya8hk-23570-00-PO front lower arm comp (1)
ya8hk-23580-00-PO front lower arm comp (1)
ya8hk-23501-00-00 steering knuckle #*$&@ (1)
ya8hk-23502-00-00 steering knuckle #*$&@ (1)
ya90105-10318-00 bolt,flange (2)
ya90201-10051-00 washer, plate (4)
ya8hk-23831-00-00 tie rod (2)
ya8hl-23743-00-00 stopper 1 (2)
stopdropanroll said:
BonelNytro said:
No one knows the difference?
I know that the cross tube on a 08 upper a-arm is smaller in diamator then a 09-11. As far as anything else I could'nt tell ya.
X2, found this out when trying to swap the zbroz arms over. went to use the new bushings from 09 upper arms and the long rod was to large.
I know they changed some front end stuff in 09 but idk if it was in the arms, spindles, or both.
I just checked some 08's vs. 09's that I have in my shop ready for powder coat and the 08 upper is also longer then the 09. I couldn't find any chages in the lowers.
So that would change the camber right? basically sounds like they did whate everyone was doing with the ball joint mod to the 08's.
