Does anyone know if it make a difference on the direction of rotation for an asphalt track? Mine is a 121x15, don't have the part number here with me, but I can't find any arrows on it anywhere and don't remember how I put it on last year. My buddy just got one and he apparently has directional arrows on his. If it helps, I can post the part number here. Thanks guys.
there should be arrows on the thickness side of the track.
there kinda hard to see.
________
Love Advice Advice
________
Love Advice Advice
Thanks srxmagic, but nothing there, checked my buddies and sure enough they are there every few inches. Oh well I took my best guess, hope it doesn't really make any difference. Don't remember what I did last year, but I should have marked it when I took it off.
SOFA-KING-FAST
If you have not made any passes drag a card in both directions on your track the direction that snags the most is the direction the track was turning
Man too bad you didn't get me that tip before, done about 10 passes on the track, I'll still try your tip and see what the results are. Thanks.SOFA-KING-FAST said:If you have not made any passes drag a card in both directions on your track the direction that snags the most is the direction the track was turning
timebandit
- Jun 27, 2005
NHRA rule book says serial number must be on left side
