Available Reverse Gears?
rx1007
Hagaman N.Y.
Hi Guys, Does anyone have any information on the best gear ratios for the RX-1? I have an 03' shorty (limited / reverse) and looking for the best all around gearing. I want to definately want to keep the reverse operable, but I believe there is only a few bottom gears to choose from with reverse capability. Is this true? What's the best (gears,chains,etc.)combo? I have 144 chisels now but had 240 1.075 Gold Diggers. ECP air filters, 165 main jets, (roller secondary) from Adirondac Blue. Not sure of the helix, weights, springs, etc. right now but can find out. Carb. springs are silver. Stock track/drivers. 23 tooth top gear. Stock bottom gear. Looking for a good top speed. Not too concerned with drag racing but would like a decent all around setup. I also received information from Lazy Bastard and others regarding my question about oversized rear idler wheels. Thanks guys. Very helpful. TY member Adirondac Blue and myself ride together (separate sleds of course!) quite often on the lake and I guess i'm looking for more top speed without going TURBO. Sorry. Any gearing,clutching,jetting.etc. setups would certainly be appreciated. Thanks for your time , Jeff (rx1007)
I've had good luck with the stock gearing. I believe it's 24/38 in the warrior.
Stock Warrior gearing is 23/38. Yamaha reverse gears come in 38 and 39 teeths and upper gears is from 19 to 24.
