Northernboy
Does anyone have the dimensions for the Avid drivers to be pressed on the shaft? I tried measuring before I removed the stock ones but they were in pretty bad shape.
NB
NB
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
drive
There you go buddy..
Northernboy
Thanks Helmic, but there is nothing...Did you forget to add a link or attachment?
bholmlate
Northernboy
I am not sure what is wrong but helmic posted a picture of the axle diagram found in the yamaha manual showing all the dimensions of the OEM drivers. you might have to be logged in to see it
Supa Dexta
If you can't see it... (I can).. Try quoting his post and see if you can see the link to copy into a new window.. And then disregard the quoted post.
Northernboy
Thanks Guys,
I can't see it because the server here at work is blocking it.
Net Nanny...lol
Net Nanny...lol
Northernboy
Ok I got the new Avid drivers pressed on and they centered where the stock ones were. Just wondering if I should move them in more, right now seems like the track can move side to side alot.
NB
NB
towerrigger
Press them in towards the inside of the track windows and this should stop the track from moving around.
