DPG44
- Mar 7, 2021
- 2022 Sidewinder L-TX GT EPS
Ski-doo Grand Touring 900
I have two 700 Grizzlies and I’m having issues as they always seem to default to 4wd and I have issues actually getting them back to 2wd.
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
I had the same issue with mine. Had to take apart the push button and clean the contacts inside. Then add new/fresh dielectric grease. Reassembled and now it works as it should.
DPG44
- Mar 7, 2021
Thanks, I’ll definitely try that.I had the same issue with mine. Had to take apart the push button and clean the contacts inside. Then add new/fresh dielectric grease. Reassembled and now it works as it should.
clean all the chassis grounds as they cause issues as well.
