DaMick85
Just pulled my 2007 RTX out of storage and I'm a little concerned about the idle. It started doing this, this past winter just never had the time to look into it and the dealer wasn't much help at all. In the manual it says that when you start the sled the yellow light for the oil temp should come on and it does and says that the RPM should be between 2800 and 3000. When I start the sled it trys to kick up the RPM and gets up to about 2200 and then drops down to the normal idle of 1500. When its cold out it takes me 4-5 starts and I have to manually hold the throttle to keep it from dying. Any help would be greatly appreciated cause the dealer told me that it was a bad tank of gas. My argument is how can a bad tank of gas affect something that is electrially controlled. Thanks for any help!
