IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
I turn the key on the ignition and gauge lights up the tachometer needle goes from one end and back. I can hear the fuel pump cycle.
Turn the key all the way to crank the motor and everything goes out.
There's nothing.
Turn the key 6 to 8 more times and something finally catches and starts right up fine.
2007 apex gt
There's nothing.
2007 apex gt
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Electrically there are a few common issues with the apex.
The key switch is not usually one, but antyhing mechanical/electrical can fail so its not out of the question.
I would be leaning more towards a bad ground in your wiring harness. If that does not pan out then i would look at the relay mounted down beside the battery.
Actually i would check the relay at the battery first, because it is quick and easy to access.
This part develops corrosion and is a known problem.
Good luck
Good luck
HABS 1
- Oct 22, 2015
- corunna,ontario
check all grounds, should be able to test just ign switch with voltmeter
HABS 1
- Oct 22, 2015
- corunna,ontario
agreed , the switch is probably good, but dont take much to testElectrically there are a few common issues with the apex.
Good luck
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
ok thanks I know what you're talking about I'll check into it
sxray
- Mar 2, 2006
- grand blanc, mi
- apex
Sounds like a bad starter relay
Start with the simple things:
-poor battery cable connection....clean and tighten cables on battery and starter relay
-check, clean, and tighten ground cable at battery and engine attachment
-charge or replace battery
Most problems are usually solved with simple maintenance
