YamahaTom
How do I change the front inside wheels on my vector?
I took off the outside wheels and the bolts on the inside wheels.
Do I need to change both?
Thanks,
Tom in CT
Thanks,
Tom in CT
YamahaTom
No buddy can help?
I took both set screws and bolts off the upper wheels, now I need to know what else has to come off or swing down. Wheels are on the mono shock on the inside, about 5 in wheels with holes in them. I was toll to replace them both. Is anyone change the wheels to after market wheels?
Changing the sizes?
Any help would be great!
Tom in CT and VT
Changing the sizes?
Tom in CT and VT
Grimm
Here's a couple of posts that should give you the answers you seek:
http://www.ty4stroke.com/viewtopic.php? ... dler+wheel
YamahaTom
Wheel change
I guess I'll unload the shock and try and get the wheels off.
Has any one changes them?
Will do it tomorrow!
Thanks for any help! Tom
Grimm
I have changed them, yes you should unload the shock. I don't have that sled anymore and give you anymore details. It is relatively easy job.
YamahaTom
How many bad wheels out there?
Please let tell me about your bad wheels and how you changed them.
Have you changed with after market wheels?
Thanks,
Tom in CT & VT
Thanks,
Tom in CT & VT
Grimm
Please use the search feature, it's all been done before.
YamahaTom
Thanks!
I changed the wheels, had a bid of a time with it, but got it done.
Not a small job, but learned alot.
Glad the 08 has a different chassis.
Thanks for all that helped!
Yes I did a search, looked thru all 254 post.
Tom in CT & VT
Tom in CT & VT
