07AttackGT
Looking to put a bar riser just curious what some of you guys are running for risers? How do the fit? quality? and what is the highest I can go on an Attak without changing cables?? Thanks I had a 2 inch ROX on my Nytro seemed to work well!
SKIP
07AttackGT said:Looking to put a bar riser just curious what some of you guys are running for risers? How do the fit? quality? and what is the highest I can go on an Attak without changing cables?? Thanks I had a 2 inch ROX on my Nytro seemed to work well!
I've got a Monsterworks articulating riser. IMHO the most you can go up is 2", I rerouted my cables for best fit and have had no problems with the extra 2" rise.
Cheers
MikeAttakNYC
skip ur pic equals
rox pivot riser 3.5 love it great for standing. didnt need to re route wires just had to remove that U shaped harness that keeps the cables together
sobfrogg
Lake Effect Risers.
Not only are they a site sponser but they make prob the best looking risers I have seen
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Muffin Works has a kit that works great with the Apex. With our adapter block and 6" risers, you would end up with a total of 8.5" of total rise when measured from the top of the steering post. Many here have used this setup and have not needed to extend any cables. The Apex adapter block will also allow you to retain use of the stock chrome trim ring. We also have been a site sponsor since 2006.
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- 17' Yamaha Sidewinder LTX DX
- Comstock Park
Risers
Im using stock mountain riser and mountain cable great combo on my attack perfect!!!!
ohh and oem mountain cable is like 20 dollars cheap!!
ohh and oem mountain cable is like 20 dollars cheap!!sledneck22
What about the brake line. Has anyone put on a 6" riser and had to extend the brake line? Does anyone happen to know the length of a stock brake line? Thanks, Kyle
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I fit the stock apex mountain risor on with stock length GT cables and it works fine, I had to re route the throttle cable but works great.
That mufflin works package looks awesome! I may want another 1" or two in the off season and will have to go to a longer cable then.
I "think" the mountain risor is 2.5" taller then stock I keep forgetting to measure as I have them both.
