ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Its for quick deflection adjusting, and also removing/installing belts.What is this for? I have a Sidewinder that had a belt blowing issue.
Dan
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Awesome looking!
I wish I didn't already have one from a different company
LouTurbo
- Dec 19, 2016
- Vaughan, ON Canada
- 2017 Sidewinder LTX LE, Hurricane Tune on the fly
Pilot Skiis,
- Woodbridge, ON
Just to clarify, are the buttons removing the need for the handheld plastic shim ?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
YesJust to clarify, are the buttons removing the need for the handheld plastic shim ?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Ive been instructing everyone to grease threads but it has come to my attention i need to be more specific. My intentions are for the threads that the adjuster spin on to be greased. Thread the center core out of adjuster and apply grease on the core threads.
Grease will help preserve the threads and prevent them from galling up. Install instructions on website will be updated soon to reflect this.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Great work Travis!Ive been instructing everyone to grease threads but it has come to my attention i need to be more specific. My intentions are for the threads that the adjuster spin on to be greased. Thread the center core out of adjuster and apply grease on the core threads.
For anyone considering this, please take alook at my build thread, i have info there on this latest design with I feel is very good! https://ty4stroke.com/threads/my-rt...et-the-mods-begin.149801/page-24#post-1412533
Dan
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Very nice Travis, not real happy with the belt adjuster I have. Do you still have a deal set up for us Canuks like when I bought your bellypan guard? Keep up the great work.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
So I've done it again....improved the design!
Had a few issues with adjusters seizing up. Some of them were my own fault as I forgot to put grease on the threads before I shipped them out. Others I think may have been due to some material impurities which resulted in cracked threads. Growing up in a welding shop my first instinct is to always build out of metal. I happened to remember one day that hygear used plastic for their threaded cross over adjusters on the mono shock dual rate spring kits. I figured if the plastic threads can with stand a mono shock spring force then why not try it for belt adjusters. I made up a test sample adjuster and it worked great. By machining the adjuster from plastic I eliminated the seizing concerns of the past.
Another issue, while no more than 5 cases was broken buttons. Very easy and cheap to warranty, but still something to fail. By machining the adjuster out of plastic, there is no longer a need for the buttons!
Lastly, the counterbore holes used to lock the allen into for leverage when doing belt change would start to wear and open up from frequent use. I opted to run a full through hole to slide the allen wrench into. This is a much better method for locking the allen wrench into the adjuster. I had to maintain the full octogon profile the whole length so the hole had some meat around it. In addition the full octagon gives more grip area for hand adjustments.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
The best gets better... way to think outside the box travis
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Is this a replacement piece or the whole tool?
Carbon 141
- Nov 3, 2017
- Corcoran MN
- 2017 Yamaha Sidewinder XTX SE 141
2002 Yamaha SX Viper 700
Are these new and improved ones ready to ship?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Yes. Didnt update photos on website but if you order you will get updated version
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Travis - Is the distance the same before the adjuster bottoms out when running a washer to limit float? I ask because it is just barely enough to get the 8JP belt off as it is today. I was hoping that pocket would be a little deeper.
