Got new recall today at the dealership for the battery on certain fx and rtx 09 nytros.There are certain serial # that have batteries with too much iron in them and they can discharge quickly when not in use.The batties in question are the ytx20lb-s.Check with your dealer.
Daranello
Suspended
really thats odd
LazyBastard
Must be a bad batch....
Its funny that they would use the ytx20l-bs in the nytro. That is the same battery used in the 03-05RX, which they switched to a ytx14-bs for 06+ in order to save weight (3 pounds).
nitrojb
I had mine replaced on my 09 FX
LJ 452
LazyBastard said:Must be a bad batch....
Wonder if they changed something in the electronics that required a battery change? Was there a difference in capacity or Ampacity?
Daranello
Suspended
So who's affected and what are the serial#'s
NH Rider
- Feb 19, 2005
Model
Model Description
Serial Number Range
FX10MTRY
FX Nytro MTX
8HA-006989 ~ 007028
8HA-007607 ~ 007634
8HA-007636 ~ 007637
8HA-007639 ~ 007706
FX10RTRY
FX Nytro RTX
8HB-006050 ~ 006159
8HB-006510 ~ 006569
8HB-006730 ~ 006829
FX10Y
FX Nytro
8GL-003830 ~ 003834
8GL-003836 ~ 003843
8GL-003845 ~ 004109
RST90Y
RS Venture
8ET-013346 ~ 013372
8ET-013440 ~ 013472
VK10Y
RS Viking Professional
8GS-009912 ~ 009961
Model Description
Serial Number Range
FX10MTRY
FX Nytro MTX
8HA-006989 ~ 007028
8HA-007607 ~ 007634
8HA-007636 ~ 007637
8HA-007639 ~ 007706
FX10RTRY
FX Nytro RTX
8HB-006050 ~ 006159
8HB-006510 ~ 006569
8HB-006730 ~ 006829
FX10Y
FX Nytro
8GL-003830 ~ 003834
8GL-003836 ~ 003843
8GL-003845 ~ 004109
RST90Y
RS Venture
8ET-013346 ~ 013372
8ET-013440 ~ 013472
VK10Y
8GS-009912 ~ 009961
Daranello
Suspended
Cool, so the XTX look to be safe
switch
SE's
Do you read the last 6 digits of your serial #?
stinx
are the SE's ok?
stinx
any updates on this?
homeskillet
Symptom: On some affected units, it is possible
the battery electrolyte contains an excessive amount of iron. The battery may self-discharge faster than normal when not in use for long periods of time.
Cause: Improper electrolyte was provided from the battery manufacturer.
Remedy: Replace the battery assembly
Dont look into this any more or any less. no electronic changes nothing just to much Iron!
- 12K
