rxwhopper
i am trying to give this speedshop hh kit a chance.this last weekend i tried it again. it pretty much runs over 10500 all the time. it will start the shoot hitting dam near 11000, then fall down to 10.6 or 10.7.so i tried going with the silver secondary spring at 70 and gettung rid of the white that i had at 60. no better.so i had a worn out belt on my holder that sat down the seconday some.that brought my rpms down to about 10.5 most of the time.what am i doing wrong.i pulled out the weights and they are set exactly as yoou said they should be. I added a thin washer at the 7/16 head bolt and 2 thin washer under the 3/8 bolt. so the setup would be 3/4 allen in heel, 7/16 bolt and a thick washer along with a thin in the middle and 3 thin with a 3/8 on the end. i never tried it yet but is there any other suggestions. I put the good belt back on.Was going to put the stock clutching back in but dammit this should work, most peaple say it is better for drag racing and thatwhat i like to do, trail ride and line up with the buds, thats my biggest fun in sledin, dragin. thanks for the help bby
