Jona$
Master
Whats the difference between apex gt 07 vs 08 due to that there are other numbers in all balls kit to drive shaft and jackshaft.
Jona$
Master
also checked the blue prints for 07 vs 08 and its identicial down to the number on both bearing,oil seal,etc atleast what would come in the kit as i can see. and on ronnies site the number set for 08-09 by all balls, ronnies sat it at 07-09 and 06- .
http://www.ronniesmailorder.com/eshoppr ... T_KITS.htm
http://www.allballsracing.com/ymmsearch ... hfromhome/
can anyone help, sitting on quite a big order half across the world so wanna get this right.
Jona$
Master
well for anyone wondering the same, found out that the difference in the kit are one more bearing on drive kit for newer due to that they have a hole in the outer chaincase. And some difference for o-rings.
So follow the line on all balls site, and not Ronnies if you want it correct!
Difference between reverse and non reverse models?
About those years it became standard equipment instead of an option. Who makes the bearings? Yamaha usually uses NTN Japanese bearings. About as good as they get.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I heard that All Balls are junk. For anything that are hard to replace or critical, better to get the good stuff or even the over priced Yamaha parts. Like my mom always said "You can't afford to buy cheap".
