zquick1
08 nytro with 4000 miles having a problem with the belt slipping. It seems to happen in the mid range area when u put a heavy load on it . any ideas ?
ericmichael
bad belt, oil on the sheave/belt. whats it doing?turning the rpms high then grabbing??more info
zquick1
tried 2 belts doesnt seem to change. it only seems too slip for a short while. clutchs are clean
asphaltkitty
check your alignment...
enticeraised
Tear clutches down, check everything-check belt surfaces
zquick1
I think it may have been getting wet from missing panel on bottom of sled. where in the hell did that go?
enticeraised
zquick1 said:I think it may have been getting wet from missing panel on bottom of sled. where in the hell did that go?
HAHA. Buddy had same issue with Nytro XTX. Hole in btm plastic from stick. Powdered snow would cause belt to slip. Belt didnt do that many times and it was no good anymore...
