02xtreme
Super Sled said:New belt (wider and not stretched out yet) equals need to have 2 or maybe 3 washers on each bolt, depending on width of washers.
Then as the belt wears and becomes thinner and stretches out you remove the washers one at a time from all 3 bolts. Really worn belts need no washers.
It's trial and error with each belt because no two belts are the exact same width.
02xtreme
02xtreme
Isn't this backwards??? New belts need no washers as lack of washers spreads the clutch plates lowering a new short belt. Old belts need more washers as this closes the clutch plates therefore raising the strecthed old belt.
I have a brand new belt and it still sits below the secondary??? No issues with clutches or centre to centre. Actually all internal components of both clutches are new/rebuild and it worked fine. Did I get a bad new belt?? My Doo belts would always sit about 1/8 inch above secondary for perfect deflection. This belt thing on the Yamaha is a PITA!!!
gun nut
I added a belt adjuster on the secondary years ago, and adjust belt height with a simple twist of the adjuster.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
the belt should sit 1mm-2mm above secondary clutch
More info please. How much? From where? Brand?gun nut said:I added a belt adjuster on the secondary years ago, and adjust belt height with a simple twist of the adjuster.
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
Picturers please never knew this was available.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Not to Hi jack the thread, but I'm looking for info on the Bender belt deflection adjuster also. Bender has almost no info on there site.
Any info would help, how to install and how it works
Super Sled
- Feb 25, 2009
- Summit X
02extreme:
You are right buddy, I was backwards in my above explanation. As I read it now I was backwards. Geez, how was I thinking that. Oh well, thanks for clarifying for me! ;-)
