can any one help. i shorted the rod 5 turnes no more boost still at 7-8 pounds on high.i am after testing for leeks and now showing 7 pounds but is not pulling the same. i am in bad need for help. i love to be able to try 12 or 13 pounds.
ANYTHING I FELL IN LOVE WITH BOOST
YAMAHA69 THANKS
YAMAHA69 THANKS
hlmrx1
Front or rear mount? If front check for header cracks or leaks in the exhaust before the turbo.
it is a rear mount bender i have not checked for leakes before the turbo are you talking about a leak somewere from the motor to were it is bolted on the turbo
BigDog05
Do you have the 2 position high low switch?
hlmrx1
I just finished having problems with mine, front mount. I couldn't get the boost to come up, kept turning the wastegate rod and boost just stayed the same. Found that the header was cracked in a couple of places, worst place was the flange where the turbo mounts. Check you exhaust pipes in the tunnel. If stock pipes I've seen a couple that have broken. Do a search, someone on the site posted pictures recently on this. It was on a stock unit.
Freak
Skydog
If you have the switch make sure it is open and not pluged up with crap or ice!
Thrusted Vector
Pressurize your intake system,and check for leaks in the charge tubes,I had the same problem ,turns out to be a hole melted in the rubber hose next to the turbo.
the switch i got is the 1 bender gave me when i bought it
Skydog
BigDog05
Make sure the line you have running from the T at the waste gate to the switch is not kinked anywhere. Make sure its not pinched under the seat or gas tank.
Blue shadow
Your jet must be on the turbo side off the T not the wastgate side,that is on the front mount.
- 10K
