bent A arms
snomo53
Geneseo, IL
After 5700 miles I have bend both LOWER A arms just enough so the bolts had to be sawz-alled out. Damage is not visible to the eye, but replacement bolts won't slide through. Anyone one had experience straightening the A arms? At about $225 each, I'm all ears here
i tried to straiten mine but wasnt sure if thet were straight or not, so i bought some new ones, it seemed to me after getting the new ones that my old ones were tweaked thats why i also had to get the sawzall out. if i had to do it over again i would buy cb performance aluminum a arms and i also installed ulmers bushing kit and it worked great.
where are they bending? Or do the bushings not meet and align tight?
my bolts are very bent and will have to be cut out. Not sure if i will be able to get them back tight. I am ordering the oilight bushings from Ulmer. Is there a stronger bolt that will not bent every season? can i heat up the a-arms and make the joint tight again? Some one said that there paint flaked off. No big deal if i have them powder coated and weld on grease zirks. Any help or ideas appreciated
