SilentSno
- Mar 6, 2007
- Montana, USA
- 2008 Yamaha FX Nytro MTX
Srxspec said:
Holy cow! I thought mine was bad. My spindle on that side is only straight up in the air. And I can see the coilover spring has rubbed in the a-arm a little bit as well.
Is it the subframe itself, or the tabs that the a-arms mount into?
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Allen, how many hours to R&R the subframe ?
What the frig dig you nail to do that !
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
It was the subframe that was bent in the lower section. Took about 4 hours for repair. Hit a rock laying along the side of a road going 30-35 mph. The rock was probably 5-10 lbs in weight and caught just right on the carbide to tweak it all.
Reaper
- Nov 10, 2005
4 hours not bad at all, also believe the part was not that expensive correct ?
- Apr 17, 2003
- Menno, SD
- Menno, SD
I believe full retail on the part is $520.
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
Did you add any extra reinforcement to the new subframe?Srxspec said:It was the subframe that was bent in the lower section. Took about 4 hours for repair. Hit a rock laying along the side of a road going 30-35 mph. The rock was probably 5-10 lbs in weight and caught just right on the carbide to tweak it all.
