titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
Like the title says putting new carbides on today and looking for the best as far as tracking straight and no darting??? I'm thinking Woodys or Stud BOY?
Snow Studs Double Downs=wider than all duellies,much better wear,85% darting gone 4,6,8 & 10" avail-cheaper also.you can get them from Johnmaster.net.
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
Studboy duece by far.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
I'd spend the extra little bit for the Semi Agressive Sno Trackers if you want it to turn in the softer stuff and have 0 darting and track perfectly straight.
If you just care about straight and reduced darting the Deuce bars are good.
Yamadogger
X2 on the Snow Studs Double Downs. Ran them on my '06GT for a couple years before I got my Snowtracker Extremes. My wife still has them on hers and has at least 5000 miles on them. No darting but a bit more push in the corners than the Snowtrackers. Best all alround dually I've run because they're wider and don't get snow stuck in between. Still need to shim your skis 1/4" though to completely eliminate the darting.
I should also put the disclaimer that I can't comment for sure on this carbide for the 2011 sleds, only that it works well on previous year Apex. Would assume similar results, however.
RollRite
- Dec 16, 2004
- Pickerel , Wisconsin
- 2011 Apex
SlimJims Work the best for me
smacho
X2 on slim jims
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
duece bar
