Best oil filter?
Sorry dont mean to steal this post but do you let your sled run a little bit before you change your oil?
I have to read the owners manual but I'm pretty sure we do have to have the sled warmed up before we change the oil
In my opinion I'd stick with the OEM Yamaha filter 5dm-13440. It's only 2" long and is better protected from the skid plate. Unless there is an aftermarket filter that is that short I'd stick with the OEM. Every aftermarket filter I have seen is at least 3/4" longer. Just bought a Napa 1358 and it sticks past the engine case. The OEM is tucked in further. Wondering if there is an aftermarket one that is just as short. Read the post on oil filter rub.
:Rockon:
I posted on a thread here last spring about oil filters. We discovered that aftermarket oil filters are longer than stock (like an HF 303) and when the stock skid plate gets bowed in a little bit, the aluminum rib will rub on the filter and could cause a leak. I saw it on my own sled. I posted pictures so if you do a search it should come up.
That sounds good, thanks for the advice. Looks like im sticking to the OEM filter.
best filter for the money hands down...
purolator pure one..
almost all aftermarket filters are available in the stock dimensions..
