rxwhopper
i am wanting to buy some extra wheels to reduce hyfax wear, what are the best ones to buy? use the yamaha accessory ones ot fix powersports? does ulmer sell any? Or should i put larger wheels on also? thanks
yamadog07
i would not suggest fix power sports, nothing but problems for me.
i ended up switching to oem & all was good.
rxwhopper
was thinking that was the only way to go. i will look into the oem
yamadog07
fix does not stand behind thier product. let alone product does not hold up.
i switched to yamaha's front & mid that mount off the rails. worked great. note that they do not mounnt in the front/middle of track like the fix kit, but they still worked as well or better.
dexter
are you guys speaking of the small front kit? I have one on the warrior and wonder if it's worth it. if not in the front where are you guys mounting it?
copo427ss
try pioneerperformance.com [/u][/url]
dexter
pioneer kit is nice, BUT you have to use the stock $80 wheels unless you machine and tweak the mounts.
CaptCaper
- Jan 1, 2007
- Northern N.H.
My slides still seem to wear even with the front wheel kit and the mid wheel kit...I still have to change them once a season..go figure
yamadog07
wheels mount on rails before the curve. takes some tension off sliders.
stuff still wears though.
yamaouch08
- Jan 17, 2006
- Otisville,Michigan
- www.chapmanssports.com
Get the Yamaha kit. I tryed a Fix Powersports kit,well lets just say it was junk,it only lasted about 400 miles. Fix doesn't stand by there work either. I then bought the Yamaha kit,with 1,600 miles on it,it still looked and worked like new.
