Next step to help hyfax wear, marginal wheel kit/s. track is super loose (only a few threads showing through adjuster nut, so cant go any looser). Excell wheels installed. DUPONT hyfax installed. And I still burned through them in about 1,500 miles. They are wearing at front curve in rail (right under rubber bump stop) and mid rail (between rear and middle idler wheels).
Was contemplating adding marginal Snow wheel kit at front of rail and mid rail. Which wheel kit do I need for each? I am assuming these....SMA-8FA95-00-00 and SMA-8FT95-00-00. Which one of those is for the front curve of the rail?
Unless someone has better suggestion?
