big problem with my skid
karlpich
Boischatel, Qc
Website
www.pelti.com
i buy apex rtx 06 with nytro 153" skid with extension to 174" i just receive my sled but tunnel have many many hole for mounting skid ! it's same mounting hole between apex and nytro skid? i would like measure if possible of a nytro skid 153" and apex please !! i'm very disappoint .... i have 3 different hole for front hole ! I'm not sure having the right dimension because I have no tranfer......
karlpich
Even though it is a Nytro Skid you may get better help over in the general Apex or apex mountain section of this forum. The monting hole on the Nytro are different from the Apex but i am sure someone has the dimensions you need. If you have that many holes it soulds like the guy was searching for the right setup. You could always mount another aluminum panel inside of the tunnel to stragthen that section of tonnul but sounds like the least of your problems if the skid isnt trandering. I am sure someone on this in this forum can help you good luck with it
