SPEEDMAX
Iam looking for info to built promax class apex or rx1 big bore and stroke on nitrous need at lease 400hp off nos any help is apriciated thank-you
langow
400HP off NOS? Or 400HP of NOS?
I don't think 400HP possible without serious supercharging or turbocharging. Nitrous alone isn't gonna get it done, I don't believe.
It can be done, it will just be a one off system for a sled. Progressive controller, Pro Shot fogger Nozzles plummed into custom intake runners, seperate fuel system for the nitrous. Start with a Nano nitrous set-up to minimize the size of the bottle needed and also to maintain constant bottle pressure down the track. The motor must have rods, lower compression pistons, head studs and a very free flowing exhaust. Get to know someone that uses big nitrous systems on a car or mud truck. These guys are putting over 900+hp in nitrous to there motors.
It would be cool to see done.
SPEEDMAX said:Iam looking for info to built promax class apex or rx1 big bore and stroke on nitrous need at lease 400hp off nos any help is apriciated thank-you
N/A motor with 400HP would be a tough build but so would 400HP of nitrous in such a small motor.
I would talk to Jason and Straightline Performance and see if it can even be done.
That's a massive amount of power on NOS. Key to going in that range requires setting up with proper timing compensation, otherwise things go BANG real fast. Not really different than forced induction -- proper ignition timing is key to success.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Not gonna happens, stock engine breathing 100% nitrous will not go anywhere close to 400hp
Lite
mulot30th said:Not gonna happens, stock engine breathing 100% nitrous will not go anywhere close to 400hp
Well, he wrote BIG bore and stroke....
But why not just ad a turbo?
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Lite said:mulot30th said:Not gonna happens, stock engine breathing 100% nitrous will not go anywhere close to 400hp
Reason being a different class for racing. I believe it can be done. Adding to wildmans post, you will be to build the motor, je pistons, Carrillo rods, ar studs, change cams, add larger injectors or an aux fuel rail, etc. Good luck, let me know The results...
