crippledncrazy
I am getting a stage two turbo kit from ulmer racing. I will be running a little higher boost than the regular kit. I will be running 10 lbs because I am getting a meth kit. Im not sure about turbos on snowmobiles, Ulmer says 10 lbs and below its not necessary. I thought a bov was just better for the over all turbo? Should I get one? also which one should I get, I am kinda let down because I was looking forward to having the bov sound. Figured I would ask on here what the benefits are and if its a good thing to have I am going to get one. Any recommendations?
the bov will help in reducing runon when you let off the throttle [boost keeping the throttle open] and sounds cool. the guys with the big boost use them for this purpose as well as being able to keep the turbo spooled up during the moments of on and off the throttle
crippledncrazy
I have a good understanding of turbos because of cars and what not. The bov would make the turbo last longer and even give better gas milage I would imagine? Also like you said performance wise it would help keep the turbo spooled up during on and off throttle times. I am gonna have to buy one damn......any suggestions? I did a search a found this on here seems like a good one
http://turboaddictionparts.com/catalog/ ... ducts_id=3
ted of tap has lots of knowledge and will point you in the right direction the valve on you're link is the same one i have the tricky part is where to put it and weld on the adapter flange
FLYBYU
Ted Jannetty will take care of you. Shoot him a PM and ask your question. He will point you in right direction and get you the stuff you need.
